Need some help...non-lowered 98-up birds.... - FirebirdV6.com/CamaroV6.com Message Board
  • Need some help...non-lowered 98-up birds....
    I got some lowering springs on my Formula and we didnt think to measure before we got them installed. The car was alot lower on the passenger side by about an 1" or more then they driver's side when I picked the car up. It has settled a little but I still come up with different measurements on each side. The front are about the same on each side. In our garage we got these measurements from floor to top of fender:
    Driver's side front: 26-1/4"
    Driver's side back: 28-1/2"
    Passenger side front: 25-7/8
    Passenger side back 27-1/2"
    You can see there's an inch difference between the rear on each side :( . Although when I measure from the top of the wheel to inside top of fender wall I get only 3/8" difference (fender gap).
    What I would like please.....if someone could measure their 98 and up bird's height on a level surface from ground to where the fender starts. We think the driver's side rear is the same as stock. Any help is appreicated!! [img]smile.gif[/img]
    Thanks
    -Michelle
    2000 Pewter Metallic Formula M6 <br /><br /><a href=\"http://flaminbird.smugmug.com\" target=\"_blank\">My 2000 Formula</a>
    No idea...email me back! :D
    AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
      could be that the car's weight isn't evenly distributed. more weight=less height, less weight=more height.
      2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
        Take all measurements from the center of the wheel.
        Raven
          Thanks for the replies guys. I'll take some more measurements then from the center of the wheeland see what I come up with.
