greasing 1le lca's - FirebirdV6.com/CamaroV6.com Message Board
greasing 1le lca's
  • greasing 1le lca's
    im putting in the 1le lca's this weekend. i was just wondering about the process of lubricating them b4 the install. how exactly does one go about doing this. ive heard it mentioned but never explained. where do you grease them at? what kind of grease do i use? any help is appreciated. thanks
    Visit My F-Body Page
    The 1le lcas have rubber bushings, I DON'T think you are suppose to grease them.
    I'm pretty sure you only grease the poly bushings.
    97 Silver Camaro M5<br />Y87 Package<br />K&N FIPK<br />Flowmaster 80 Series<br />Mille Miglia MM11-2 18x9 wheels<br />Kumho ECSTA 275/35ZR 18s<br />Centerforce Dual Friction<br />B&M Ripper Shifter<br />1LE Aluminum DS<br />BMR LCA\'S<br />SLP 1.8 Rockers<br />ZZP UD WP Pulley<br />H&R Sport Springs<br />Spohn Adj PHR<br />160* Thermostat
      They say you don't have to grease rubber, but I had to grease the 1LE rubber that wrapped my rear swaybar (bushings) because it was squeaking really bady.
      Make sure the grease you use won't deteriorate the rubber if you want to use some. I probably wouldn't use any though on rubber LCAs as the bushings have steel liners.
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        well, ill stick them on this weekend and see how they sound without.
