I've heard that you need to have the car jacked up horizontally, well I don't have access to a car lift or anything of that nature and I do not feel comfortable having the whole car lifted with jack stands. What I'm asking is, can I jack up and put a load on JUST the rear of the car and remove the bushing fairly easily? Or am I better off raising the whole car up evenly and doing it that way? While we're on the subject, anybody got any tips to make this removal, installation any easier? Thanks a lot guys!
Help with removing and installing TA Bushing
Black 99 M5 Camaro \"6BANGER\"<p>Sport Appearance Package, Whisper Lid, SLP Cold Air Kit, K&N Filter,Dynomax Custom Cat-Back, BMR STB, Jet Stage II Module, Centerforce Dual Friction Clutch, Hurst Shifter with Custom Short Stick, RKSport 2\" Drop Springs, SS Hood, Poly Tranny Mount & TA Bushing, SLP 3.42 Gears with LSD, All Amsoil Synthetic LubricantsTags: None
i have a tip.. get it all the way up on 4 jack stands..
it would be almost impossible to get your TA off the rear housing if you do not jack it up..
At a minimum you need to have the rear jacked up..
and you probably wotn be able to get to the bushing w/o jacking hte front.. so..
good luck.. installing the bushing is a pita and not really worth it in my opinion..
get an edelbrock ta and do it then.. it comes with a bushing..
~Billy
Thanx ALLTHEGOODNAMESAREGONE, at least you at least helped me out, everybody seems really repsonsiveBlack 99 M5 Camaro \"6BANGER\"<p>Sport Appearance Package, Whisper Lid, SLP Cold Air Kit, K&N Filter,Dynomax Custom Cat-Back, BMR STB, Jet Stage II Module, Centerforce Dual Friction Clutch, Hurst Shifter with Custom Short Stick, RKSport 2\" Drop Springs, SS Hood, Poly Tranny Mount & TA Bushing, SLP 3.42 Gears with LSD, All Amsoil Synthetic Lubricants
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...2 days ago
