.. i have new pads, all around, and my cousin who is a mechanic said my rotors are fine. he blasted my pads with air 5 days ago and the prob went away for a day or so, but then they started to squeek again. i got the pads from o'reiley, and they said that nowadays pads will do that... no asphestos (no s#it shurlock). so why is it that i dont really hear other newer cars with the same prob? i doubt they go heve them blased with air every couple a days. what should i do?
my brakes squeek too, but...
You might want to put antisqueal on the back of the pads, it sometimes helps with things like this.2002 5-spd NBM Camaro
Details: www.1lev6.com
What's antisquel? I got the same problem with brakes squeaking but there's nothing wrong with them.
<blockquote>quote:</font><hr>Originally posted by Dominic:
You might want to put antisqueal on the back of the pads, it sometimes helps with things like this.<hr></blockquote>
im thinkin its excessive brake dust... so would drilled and/or slotted rotors fix the prob you think???2001 camaro v6 red convertable<br /> ggotta go fast... I GGOTTTA GO FFAST! CCANT HEELP MMMYYSSELLLF<br />pics:<br /><a href=\"http://www.cardomain.com/id/darkthoughts5000\" target=\"_blank\">http://www.cardomain.com/id/darkthoughts5000</a>
anti squeel is a can of stuff you put on your pads/rotors to help stop squeeling..
you can get it at most any auto parts store..
LOLOL..
"im thinkin its excessive brake dust... so would drilled and/or slotted rotors fix the prob you think??? "
new rotors may fix it.. but it will also take care of that money in your wallet too..
I wouldent go down the new rotor road untill you atleast try getting them turned at a shop..
~Billy
It might be your pads.
I put new pads on, and mine started squeeking. So I took it all apart, used a wire brush and sanded all the mating surfaces down, and put some of that anti-squeel stuff on the mating surfaces. (In the auto stores here, it comes in a packet, but I have also seen it in a can) This did not fix the squeeling. I talked to a buddy that was working at a GM dealer, and he talked to all the mechanics and gave me 3 other brands of stuff to put on the mating surfaces to stop the squeeling.
Well, I took apart the brakes three more times, trying each brand. Every time my brakes just kept squeeling. So again I take it apart, and I lightly sand the pads friction surface, thinking that maybe it had glazed. Still squeeked. Finally I dished out the $80 bucks for a set of NAPA Ceramix brake pads, took the brakes apart for the 6th time, and installed thoes without any kind of anti-squeek junk, and haven't heard a sound out of them for over a year now.
Good luck.<a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
NAPA ceramix huh... how much those cost??? if not too much, ill get those and install em tomorrow.2001 camaro v6 red convertable<br /> ggotta go fast... I GGOTTTA GO FFAST! CCANT HEELP MMMYYSSELLLF<br />pics:<br /><a href=\"http://www.cardomain.com/id/darkthoughts5000\" target=\"_blank\">http://www.cardomain.com/id/darkthoughts5000</a>
a lot of newer breaks squeel. its the type of pad or something. i know one of the drawbacks of the breakdust-less ones squeel a lot. or something like that.\'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
