switching tire sizes - FirebirdV6.com/CamaroV6.com Message Board
  • switching tire sizes
    i switched from 235/55r16 all around to 245/50r16 just on the rear. will this throw off my speedometer, etc? thanks!
    95 Med Quasar Blue Camaro M5<br />-free ram air scoop<br />-removed silencer/cut airbox<br />-slp air temp module<br />-tb bypass<br />-160* thermostat<br />-underdrive pulleys<br />-installed my own t-tops! best mod yet!
    Yes, you will be going a little slower than you think you are, and the distance you travel will be a little bit less. Try google search and look for a tire size calculator. It should be ok if you have the same brand and model of tires on front and back. If not, it will likely get squirrely when beyond the limits of traction for one of the pairs of tires. You could go 245/45/16 all around and lower the car 1/2" and improve gearing by about 7% at the same time. Bad for gas mileage on the highway, but good for acceleration and handling, usually. The same is true for the 245/50/16, but to a lesser degree.
    BobC
    [ December 31, 2001: Message edited by: BobC ]</p>
      ok... how can a new set of tires throw off the speedo? I have the same 235/55/16 and I am looking to get some new tires (they came with Y87). I looked on tiretracks.com but couldn't figure out what the 55 means - 235 is width, 16 is tire size, so far that's all I know [img]smile.gif[/img]
      \'96 dark green V6 Firebird<br />Y87 Performance package<br />front license plate with silver firebird insignia<br />alpine CD deck<br />T-top<br />Tinted windows @ 27%<br />low mileage (just broke 45000 not long ago!)<br /><br />waiting for first performance mod :)
        <blockquote>quote:</font><hr>Originally posted by lostatlantis:
        ok... how can a new set of tires throw off the speedo? I have the same 235/55/16 and I am looking to get some new tires (they came with Y87). I looked on tiretracks.com but couldn't figure out what the 55 means - 235 is width, 16 is tire size, so far that's all I know [img]smile.gif[/img] <hr></blockquote>
        Your speedometer is calibrated to a certain tire size. A taller tire will make less revolutions than a smaller one in the same distance. The 55 in the tire dimensions in the height ratio of the tire. Example- 235/55/16 is a taller tire than a 235/50/16.
        2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
          The overall diameter of the tire is so close to the original that you have nothing to be worried about.
          Overall diameter of 235/55/16 is 664.9mm and on 245/50/16 it is 651.4mm. So, the difference is 1.35cm which equals to about 1/2".
          235 = width of the tread in millimeters
          55 = aspect ratio = height of the sidewall is 55% of the width of the tread
          16 = rim size in inches
          Later!
          TS
          <a href=\"http://www.suikkari.net/camaro_pics\" target=\"_blank\"><b>2000 Camaro Z28</b></a><br /><br /><a href=\"http://1texfinn.cz28.com/photo3.html\" target=\"_blank\">2000 Expedition Eddie Bauer</a>
            Oh, and Tirerack's wbsite has a lot of good info about tires in general. Check it out!
            TS
