LOWER pricing for T BYRNE suspension components! - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • LOWER pricing for T BYRNE suspension components!
    We are now offering lower prices for our T BYRNE Motorsports suspension components. Our heavy duty control arms are constructed of 1.65" diameter .120 wall tubular steel and feature Energy Suspension bushings with zerk fittings. Each arm is powder coated in bright red.The T BYRNE double adjustable panhard rod is constructed of 1.25" diameter .120 wall tubing and has Hymn-joints at each end that will allow you to center your rear as needed. Each non-adjustable panhard rod is constructed of 1.25" diameter .120 wall tubing and is powder coated in a bright red finish with Energy Suspension bushings/zerk fittings at each end. And finally our 2 point weld in subframe connects will virtually eliminate body flex and give your car the added strength that it needs. These connectors will also help improve your straight line performance and all around handling. A recommended modification for t-top cars.
    New pricing is -
    TB5000
    T Byrne Motorsports Trailing Arms
    $109.99
    TB6000
    Non-Adjustable Panhard Rod
    $89.99
    TB8000
    Double Adjustable Panhard Rod
    $119.99
    TB7000
    2 Point Weld on Subframe Connectors
    $129.99
    Tom
    <b><a href=\"http://www.tbyrnemotorsports.com\" target=\"_blank\">T BYRNE MOTORSPORTS</a></b><br /><br /><b>Order line - 1-877-4-TBYRNE<br />E-mail -<a href=\"mailto:tbyrne@tbyrne.com\">tbyrne@tbyrne.co m</a></b><br /><br /><b><a href=\"http://www.tbyrne.com/pricematch.htm\" target=\"_blank\">Price Match Plus policy</a> </b>
    Excellent Tbyrne, here's a ttt for you. I might snag a panhard rod from you soon, I could use one. :D
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
