3000Gt Suspension - FirebirdV6.com/CamaroV6.com Message Board
3000Gt Suspension
  • 3000Gt Suspension
    has anyone ever driven a 96+ 3000GT?
    there is something on them where you can press a button where it changes the suspension to "sport or touring suspension" i think.
    anyone know what this involves? I drove one and it seems a lot more stable than my Camaro on turns, etc. Is it gas shocks or something like that? and how can I make my Camaro handle similarly since the 3000gt is a heavier car than my Camaro, but yet feels more stable in turns and manuvers.
    Most likely like an active dampening system
    Stiffens the shocks with a push of the button.
    My hal's have a knob
      you can get a setup w/ certain shocks that allow u 2 tune ride quality from the cabin. I've also heard of a setup where somebody was able to make a custom system to adjust his koni's from the cabin
        I'll do some research on this, I wonder if it works a lot like the 50th anniversary magnetic ride control on corvettes? Top notch adjustable systems utilize a central pneumatic system controlled by a piston which can be adjusted under the hood or in the cabin. You can adjust the firmness of the shocks with the compression of the gas in all 4 shocks through moving the piston in/out.
        The only issue with adjustability like this is it doesn't change the curve of the rebound/compression of each shock, it just stiffens or loosens both linearly. The true hipo shocks are ones like Koni DAs that allow you to individually control compression and rebound - theyre quite ingenious [img]smile.gif[/img]
        A good set of properly valved shocks for your car will make it drive better and outhandle that 3000GT btw... but stock for stock I know what you mean.
        2002 5-spd NBM Camaro
        Details: www.1lev6.com
          my buddy's C5 goes from like 'Normal to Sport to Performance' on its little selector knob right next to the trac-control...you'd prolly have an easier time getting parts FROM a GM to work ON a GM than from a ****subishi.
            there are alot of cars with this type of feature, the newer vettes, thunderbird super coupes.. some caddys.. there are also alot of different ways to do it..
            I think RK sports sells a kit so you can do this to your camaro.. i think its a kyb kit..
            ~Billy
              My friends mom has a C4 that has that. There's a knob on the console that says sport, touring, and performance i think. I believe it's called the 207 suspension package, and it's essentially the precursor to the new magnetic system. Very cool feature; I wish we could get something like that.
              ____________________________________________
              1994 Med Quasar Blue L32 M5 Camaro
              K&N filter, Eibach Pro-Kit, KYB Gas-A-Just shocks, PFC carbon metallic pads
                "The only issue with adjustability like this is it doesn't change the curve of the rebound/compression of each shock, it just stiffens or loosens both linearly. The true hipo shocks are ones like Koni DAs that allow you to individually control compression and rebound - theyre quite ingenious "
                Check these out:
                http://www.penskeshocks.com/8760.htm
                Unlike some shocks, where "4-way adjustable" means one adjustment with 4 settings, these are truly 4-way adjustable:
                fast bump, slow bump, fast rebound, slow rebound
                That's cool (and no doubt wildly expensive).
                  <blockquote>quote:</font><hr>Originally posted by V6Bob:
                  Check these out:
                  <hr></blockquote>
                  Thats really cool V6Bob.. the shocks I was referring to were the air-type that RKSport sells. Thanks!
                    Something like FX5 or F37 on the C4.
                    Similar thing on the C5s, but I think it uses MR fluid.
                    RKSport is air-operated, 5-position, one-way crap. Get them if you like air leaks, as I hear.
                    Quad Penske's, yeah, bling, I've got $2,000 for each shock.
                    Oh you'll definitely see me changing in-car during my 60 sec autocross runs? Or those 15 second 1/4 blasts? Umm ... set once and forget it, screw in car.
                    My coming setup (should be delivered this week): Front HALs, Rear CE-2700's, 1LE springs all around, rear passenger bag.
                    -Rob
