does anyone know what the squeak is caused by... are these shocks out or just ...squeaky... im getting bilstein HDs soon and someone might buy my shocks but i dont want to sell them broken shocks...
I have had a hanger come apart and make a similar noise....
Its unlikely but I still think its very unlikely your suspension is causing so many problems on a '01
Another thought(not as easy to check) IS if the rubber boot is worn through or fell off at the top of your rear springs. Its a boot that is between the spring in teh frame. If ts missing it would rub the spring on the frame and the more you bounce the more it wouls squek. ITs likely the shop dropped your rear when they installed your exhaust and they might have put the springs back in wrong.
