spring question - FirebirdV6.com/CamaroV6.com Message Board
spring question
  • spring question
    is there a difference on V6 and V8 front springs and shocks? is $50 a good price for V8 front springs and shocks? would i need them-remember i am putting in an LS1. they have 5000 miles on them.
    6s.......under the hood or under the belt, they just dont cut it.
    I would buy them if I were you....there is a difference..the V8 springs are stiffer and so are the shocks.
      It would be a good idea to get them. Otherwise when you put in the LS1, the front will sag a little (LS1 is a little heavier then L36). $50 sounds like a pretty nice deal!
      Chris
      <b>2002 BSM TransAm WS.6 M6</b><br /><b>350rwhp, 365rwtq</b><br /><b>Stock:</b>13.455 @ 105.39 2.129 60\'<br /><b>Mod:</b>12.449 @ 113 1.832 60\'<br /><br /><b>2004 QSM GTO M6</b><br /><b>303rwhp, 329rwtq</b><br />Stock: 13.74 @ 102.14 2.1 60\'<br /><br /> <a href=\"http://members.cardomain.com/silvertaws6\" target=\"_blank\">http://members.cardomain.com/silvertaws6</a> <br /><br /><b>1984 Firebird S/E M5</b><br />2.8L
        do you mean it will be lower in the front and give the car that "mean" stance? or will it just look like crap?
          hey nino, are you doing a v8 swap? the springs i sold you are for a v8 so they will work just fine. it should also lower it a little more in the front.
          94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
            the v8 has higher spring rates youll be set with them
            •)))2000 3.8L V6 FIREBIRD (Navy Blue) 5 speed <br />•Aluminum Alloy 3-piece custom built wheels - 17x10 (front)- 17x11.5 (rear) Tires:Front: 275/40-17 - Rear:315/35-17• Suspension Techniques 1 3/8 \" Solid front Sway Bar• H&R Springs • Koni revalved double adjustable shocks (front)• Bilstien Custom Revalved shocks (rear)• K&N •Magna Flow Dual Exaust• Stock wheels W/Hoosier Road Racing tires • Sound System•<br /><a href=\"http://www.cardomain.com/id/o0oskamo0o\" target=\"_blank\">•THE RIDE•</a>
              <blockquote>quote:</font><hr>Originally posted by Predator Bird:
              hey nino, are you doing a v8 swap? the springs i sold you are for a v8 so they will work just fine. it should also lower it a little more in the front.<hr></blockquote>
              yes sir, swap should be done by the end of the month.
              i still have the front springs, never got around to putting them on. i guess now will be the perfet time. thanks adam, you saved me a few bucks again
