hi guys, i have a set of sumitomo 245/45ZR17 HTR+ tires on my car. I was wondering what PSI I should keep in them, the max PSI rating for them is 60PSi however I keep them at 40PSI, my friend says that the rear tires should be kept at a lower PSI, but I don't know what to think about that. I've had the tires ever since last august 02 however the rear tires are starting to wear really badly in the middle. I keep a check on the PSI levels every week. I was wondering what some of you guys do to keep your tires in good conditions and which PSI ratings i should use. I haven't rotated the tires yet, im afraid to because the front ones are in really good condition and I don't want them to get worn out like the rears. I'd appreciate it if only those who knew a lot about these types of situations reply. I don't want to be given the wrong advice.
Thanks, Ted
Thanks, Ted
