installing SFC's, CA's and panhard... suggestions?
ok guys,
i orderes the bmr parts, ans the sfc's are weld in, i was just wondering before me and my buddies attacked the install if there was any good pointers or important info u can give me? or is there any other parts/accessories im gonna need? were gonna have the car up on a hoist, and we do have a jack to hold the rear end up when we take off the old ca's.
thanks
later,<br />alan<br />1999 bright red v6<br />3800 series III<br />208\\210 comp cam<br />3000 stall edge tc
For the LCA's, I'd say take your time, grease them up, and make sure the bolts are torqued down to the factory specs so you don't get a rattle. Also, do 1 at a time.
if you are gonna do the weld in SFC's yourself just be careful not to get the weld too hot.. you can set the carpet on fire.. you might wanna pull the carpet up in the spots above where they weld in..
also on the driver side be careful of the fuel lines!!
-Brad
2000 V-Star Custom 1100
:rock:
3 days ago
