KYB Gas A Just Shocks - FirebirdV6.com/CamaroV6.com Message Board
  • KYB Gas A Just Shocks
    I've been looking around at upgrading my shocks and found KYB Gas A Just shocks (not the AGX adjustable ones) and was wondering if anyone has these or has any info on them. Thanks!
    I can\'t drive 55<p><a href=\"http://www.geocities.com/kotenberger/camaro.html\" target=\"_blank\">My Camaro</a>
    The stock deCarbons are a much wiser choice than these. I discussed these specifically for OEM replacement purposes with Sam Strano and he showed me where they were valved terribly for our cars... Way too much compression, no rebound capabilities. They're basically setup backwards and work very poorly - I advise highly against these.
    If you need new shocks the SLP takeoffs are your best bet right now unless you want to spend more for a performance gain [img]smile.gif[/img]
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      I have these shocks, but I also have aftermarket springs (Eibach Pro-kit). They're ok, but I wouldn't reccommend them. If you have stock springs just get the deCarbons. If you have aftermarket springs, better shocks are pretty much a necessity. The increased compression (because of the shorter spring) and the more powerful rebound will wear down stock shocks pretty quickly.
      1994 Med. Quasar Blue 3.4l V6, Borg-Warner T5, Eibach Pro-Kit, KYB Gas-A-Just shocks, K&N air filter
      soon to come: dual exhaust
