turning the rotors.. - FirebirdV6.com/CamaroV6.com Message Board
  • turning the rotors..
    a quick question, Can I have my cross drilled and sloted rotors turned. I wasn,t sure if it makes a difference. Thanks gman211203
    member.cardomain.com/gman211203
    I dont believe so...
      of course you can have your rotors turned!!
      you just need to make sure it has enough
      rotor left.
      its got to be a specific measurement across.
      it clears up minor warpage problems
      which is prone to happen sometimes.
      like $8/rotor at Oreilley's
      I'm sure alot of shops can do it.
      edit: i dont recommend it cause it takes off
      the (thickness) size. so you have less rotor
      left over. so i think it costs too much
      and i think i've heard something else bad about
      it but cant remember..
        I've heard that you can have slotted rotors turned no problem.
        But getting drilled rotors turned is a No-No.
          6 days ago
