Will it fit? - FirebirdV6.com/CamaroV6.com Message Board
Will it fit?
  • Will it fit?
    I'm planning on getting 17" z06 wheels and putting 245/40/17 on the front and 275/40/17 on the back. I am also probably going to lower the car 1.75". Should that all fit properly without rub or anything?
    Metallic Navy Blue \'98 Firebird A4<br />Free Ram Air, 2.5\" Magnaflow Exhaust, Custom Tune<br />15.43 @ 87.8
    As long as you get wheel fitments designed for the Fbody, ie. around 56mm offset.
    I wouldn't put a 245 on a 9.5" wide wheel, it'll look too narrow.
    If you're getting the 17/18" staggered wheels they are usually a 8.5" front and 9.5" rear. Then you could do a 245/45R17 and 275/35R18
      x2
      I would also like to add that I had to get an adjustable PHB and grind off my rear bumpstops.
      I mean I didn't HAVE to grind them off, but for piece of mind that my PHB with loctite in it comes undone and my tire rubs at 70+mph.
