i was in the middle of doing my coversion to my camaro when i was taking off the lower A-arm. i hit the bottom of the knuckle to loosen in but when i went to take the rest of the castle nut off, the bolt turned with the nut, i didn't know how to get if off. i could greatly use any help asap
also, does anyone know what part of the brake line needs to be bent forward.
[ April 01, 2002: Message edited by: bustacap54 ]</p>
2. If you don't have any load on the bolt, temporarily put a load on it long enough to get the nut broken loose. Sometimes as little as wedging a screwdriver in there somewhere. Maybe setting the rotor against a wooden block and letting the car down just a little against it.
There will be a metal brake line coming into the wheel well and it goes into a bracket and then adapts to the rubber line. That bracket where the two lines meet you will want to bend down a little to like a 45 degree angle. Maybe a little less.
This is also a good time to replace ball joints while you are under there. Just fyi
2 days ago
