Replaced Bushings - FirebirdV6.com/CamaroV6.com Message Board
Replaced Bushings
  • Replaced Bushings
    I replaced my LCA and panhard bushing with poly from Prothane and my tranny mount with 1LE.
    It was quite a PITA to get those LCA bushings out, but I did.
    They are great and I am very happy with my setup so far. They don't squeak and my rear is a hell of a lot more solid. I can finally powerslide around turns, its quite fun.
    I also did the tranny mount, my stock one was busted and the new one was a huge improvement.
    The LCA bushings were NOT trivial. I would only recommend changing the LCA bushings if you have some good mechanical know how and tools.
    A poly torque arm bushing is going in as soon as I get some time.
    1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
    How difficult was it to change the trans mount?
    I wish you luck with poly LCA bushings, I guess since the stock LCAs flex a little and can twist some it hopefully wont bind up too badly.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      The trans mount was incredibly easy, it only took about 30 min and that was with cleaning the support bracket.
      This site has some great install guides http://www.installuniversity.com/
      I was trying to solve a problem I had with the driveshaft hitting but even with the tranny lowered a good inch it is still hitting the tunnel.
      Another note, since the mount did lower the tranny a bit, it also in effect lowered my 3"in pipes to the point where they were resting the chassis brace connecting the subframe. It sounded horrible when I ran the car.
      I had to remove the brace temporarily until I can make some spacers out of some steel shim.
