I am going to Norwalk on the 7th of july and i only have the funding to get one of the two. i could make my spohn order, which consists of LCAs' and a pan hard rod. or bfg drag radials. I dont get any wheel hop with my torque arm. either mod will lower my 60s' but which one first???
DRs' or spohn
DRs' or spohn
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
thanks ross.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
Originally posted by Arctc Wolf:
u already have a torque arm, so get dome DR's and then later, if u need the lca/phr pkg, u can do that. lca's help straight line launching, phr's help cornering.
Originally posted by hawgs:
</font><blockquote>quote:</font><hr />Originally posted by Arctc Wolf:
u already have a torque arm, so get dome DR's and then later, if u need the lca/phr pkg, u can do that. lca's help straight line launching, phr's help cornering.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
PHR..cornering?.... :rolleyes:2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
