Z28/y87 rack upgrade - FirebirdV6.com/CamaroV6.com Message Board
  • Z28/y87 rack upgrade
    i know a guy with a z28 rack for 40 bucks. is that all I need to do the mod to my car? Is there anything else I need like tierods? Will mine work?
    Mystic Teal Metallic
    ET:15.1 NA 14.3@96 MPH 75 Dry Shot
    thanks a lot guys for your help. No one ever posts anymore. I'll post on camaroz28 whenever I need help. This site is just falling apart i guess.
      Just because nobody posted doesn't mean they don't want to help, maybe they don't know the answer to your question. Other than driveshaft or rearend, not many people start swapping parts from V8's into their cars. Sometimes you just have to be the pioneer. I ran into the same thing when I did my 98+ front brake conversion.
      If I had to guess I would say that you probably don't need to swap anything but the rack. I don't see 2 different part numbers for tie rods so it appears they are the same for V6/V8.
        All you have to do is change the rack/pinion its the same exact thing it is just valved differently.
        1999 Pontiac Trans Am M6 Far from stock.....
          so all i need is the rack? Is the pinion a separate part?
            I'm pretty sure the pinion is part of the rack and is replaced as one unit.
              ITs a rack and pinion its all one big piece, just have to swamp them out.
