15 inch wheels - FirebirdV6.com/CamaroV6.com Message Board
15 inch wheels
  • 15 inch wheels
    Does anyone knows of 15 inchs wheels that will fit on a 98? I have tried different models but none of them cleared the big brake caliper. These wheels will be used for winter purpose only.
    Thanks for your help.
    I don't think any 15" rim will fit the 98+ because of the large calipers and rotors. I may be wrong though...
      ive seen em with 3rd gen 15 inch wheels.
      Mystic Teal Metallic
      ET:15.1 NA 14.3@96 MPH 75 Dry Shot
        I don't think they fit as-is, you have to grind away part of the caliper to fit 15" wheels.
          which 15 are you talking? I run prostars all around had to use spacers and grind the rear calipers though.
          g
          2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
            I'm talking about any 15 inch wheels. Cheaper the better cause these will be my winter wheels...
            teal99camaro, when you say you've seen em with 3rd gen 15 inch wheels, are you talking about those ?
            http://www.lakeshorewheelandtire.com/wheels/1276.JPG
              try going to the junk yard and picking some up,might not look good..but they might do the job
                Theres a guy I know with 15" Bogarts on his 2002 Z28. Not sure if he did anything though, he might have, because he has the ability to. He owns a performance shop here.
                Metallic Navy Blue \'98 Firebird A4<br />Free Ram Air, 2.5\" Magnaflow Exhaust, Custom Tune<br />15.43 @ 87.8
