can i fit a 285/40/17 on a 17x9 ss wheel? I want a lil bigger than 275's if possible. thanks.
tire question
You can fit it no problems. There are people that have been known to put 315s on 9.5" wheels... though I would not advise that, not very safe.
285 you should be fine though. Only drawback is there are not nearly as many choices in tires when you go from 275 to 285... so tires might be a bit more expensive and the different between the two is little. [img]smile.gif[/img]
Originally posted by hawgs:
285 you should be fine though. Only drawback is there are not nearly as many choices in tires when you go from 275 to 285... so tires might be a bit more expensive and the different between the two is little. [img]smile.gif[/img]Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
i did stuff the 285's on the back wheels, I bought goodyear eagle gsc's 285/40/17 corvette tires and perelli{sp} p6000's 255/40/17 for up front, i will get some pics up soon.2005 Cavalier LS Sport M5<br /> <a href=\"http://members.cardomain.com/firefighter8615\" target=\"_blank\">http://members.cardomain.com/firefighter8615</a>
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
