on a 98 or newer Camaro. I know the one guy put them on his 94, but I wanted to know if anybody knows if the 98 and newer will set the same. I'm hoping they keep the stock height. Thanks.
Has anybody put V8 springs......
Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350Tags: None
You already have V8 springs in the back, and the fronts are just a bit softer than the V8. So changing to V8 springs really won't do much for you. See the Technical Database for the spring rates for each year.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
I was going to only change the front springs. The rates in the database are 225lb/in for the V6, and 292lb/in for the V8. I don't want to get too hard, as I commute in it everyday, but I want to see if they will help keep the car from nosing in so much.
I will be putting 1LE sway bars and panhard rod on, along with Bilstein HDs, along with the V8 front springs.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
Ahhh, thanks Backfire (sorry, I couldn't remember your screen name).
Dom, how are the front springs? Judging by the rate for them, they sound like they are pretty stiff, especially being that they're linear rate springs. I was thinking of going with the 1LE rears, if I wanted the rear stiffer, and if the Bilsteins didn't help much. I'm just leery about going to a linear rate spring as hard as the 1LE fronts.
I'll just go ahead and try the stock V8 fronts for now, because I can pick up a set here for free, so I'll swap them when I get my struts changed. Then, I'll go from there.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...6 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
