255/35's will fit, even w/ a drop...just do some research on the specific brand you want...255 is the width in millimeters and the 35 would be the percentage of the width that makes up the height of your sidewall...good luck
1999 Black Camaro M5<br />FTRA Kit:Whisper Lid w/ K&N<br />Dynomax Exhaust w/ Quad Tips<br />Eibach Sportlines:Jet Pcm<br />BMR STB:Frt/Rr Sway Bars:<br />Adj Panhard Rod:B&M Ripper<br />18x9\'s w/ 255/35\'s:5% tint<br />Alpine Head & 12\" Sub
255/35's are mighty small... you need to be running P275/35 or P255/40 (if they exist). If you cant run those two you need a hypertech to adjust that speedometer, it will be very different with such a huge decrease in tire height.
