Ive got some really bad wheel hop, happens when I try to take corners fast, or when I try to do burnouts, sometimes off a hard launch at the track too. Its really pissing me off, is there a way to cure wheel hop?
Decreasing wheel hop?
1998 Firebird 3.8, A4<br />Mods: Alum Ds, Yank TC 2800 stall, Rksport lid, FTRA, SLP air temp sensor, K&N, Flowmaster catback 2.5\" w/cutout, 3:42 gears w/LSD<br />Best E/T: 15.6 @ 86 mph (w/o gears / lsd or verter)<br />Best 60: 2.234<br /><a href=\"http://www.teamfoxfire.iwarp.com\" target=\"_blank\">www.teamfoxfire.iwarp.com</a> -- club site<p>To come?: l67 piston package hardened, turbo? spray? low 12\'s? well seeTags: None
Trailing arms instead of torque arm
I run hotchkis boxed
Install of them completey eliminated wheel hop on my bird
Trailing arms are cheaper and easier to installRace car - gone but not forgotten - 1997 firebird V6
kewl thx guys. Ill order myself a set of those.1998 Firebird 3.8, A4<br />Mods: Alum Ds, Yank TC 2800 stall, Rksport lid, FTRA, SLP air temp sensor, K&N, Flowmaster catback 2.5\" w/cutout, 3:42 gears w/LSD<br />Best E/T: 15.6 @ 86 mph (w/o gears / lsd or verter)<br />Best 60: 2.234<br /><a href=\"http://www.teamfoxfire.iwarp.com\" target=\"_blank\">www.teamfoxfire.iwarp.com</a> -- club site<p>To come?: l67 piston package hardened, turbo? spray? low 12\'s? well see
Gonna kill your cornering if you get boxed lca's -- I bet you get a lot of wheel hop accelerating out of a turn.
Boxed lca's won't help that much. They resist twisting too much and will create bind in your suspension.
Boxed only for drag, rod-end for serious performance (great for drag or cornering, but a tad expensive & require maintenance), 1le for budget applications.
Boxed -- I hear Hotchkis is the best
Rod -- www.lgmotorsports.com -- they have a rod-ended (race adjustable) set of LCA's w/ a poly bushing on one end and a rod on the other. Makes it more streetable. 199, will need to replace the rod end every 10k miles or so.
1le -- find the part number & head over to gmpartsdirect & grab it2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
thx for letting me know about the cornering issues, I do plan to try other things than drag with the car so perhaps ill look into the more expensive suspension mods.1998 Firebird 3.8, A4<br />Mods: Alum Ds, Yank TC 2800 stall, Rksport lid, FTRA, SLP air temp sensor, K&N, Flowmaster catback 2.5\" w/cutout, 3:42 gears w/LSD<br />Best E/T: 15.6 @ 86 mph (w/o gears / lsd or verter)<br />Best 60: 2.234<br /><a href=\"http://www.teamfoxfire.iwarp.com\" target=\"_blank\">www.teamfoxfire.iwarp.com</a> -- club site<p>To come?: l67 piston package hardened, turbo? spray? low 12\'s? well see
The rod really aren't that much more expensive. In maintenance, yes, but the initial investment isn't much more (might even be cheaper than hotchkis boxed).
I wouldn't go with another brand of rod-end lca's than LG, quality issues (especially w/ the rod ends, BMR's will make a lot of noise & will wear quickly). Realize though you may get some noise from a rod-end lca. Great places for research are the autocross forums on ls1.com and the supension forums on ls1tech.com. Both have a lot of excellent posts about lca's.
Really not making enough torque to need a torque arm, and the lca's should give a little more improvement than a torque arm will for less money.
If you plan on autocrossing, don't do either right now until you are comfortable with the class they will put you in -- which I am looking that up right now & will post again in a few.2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
If you are going with 1LE I would recommend going to LMperformance rather than GMpartsdirect. LM is cheaper.
I personally did new prothane poly bushings in my LCAs and Panhard bar and got rid of all wheel hop on the road, I havn't tried them at the track yet. I wouldn't recommend doing those yourself unless you are very confident with you mechanical ability and have about 4 hours to press the old bushings out and the new ones in.
You also may want to consider a torque arm bushing. With the power that our cars put out, it is probably the most efficent way to upgrade that.1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
<blockquote>quote:</font><hr>Originally posted by strobhen:
1le -- find the part number & head over to gmpartsdirect & grab it<hr></blockquote>
I run hotchkis boxed trailing arms and pan hard rod.
When I had a strut tower brace and power steering my bird handled like a mo fo!!!
Handling was incredible.
In my experience traction and handling improved drastically.Race car - gone but not forgotten - 1997 firebird V6
I have BMR LCA's and they're fine for me. No noise and no visible wear. The key to no noise is greasing the bolts you put in there, otherwise when it gets cold and everything gets a little smaller the LCA tends to bump the bolts making sound when you hit bumps or whatever. I absolutely LOVE the BMR LCA's. My launches are better (thus my 1.874 60') and cornering is better too. We're having a Group Purchase on BMR products at www.fbodytrader.com and a set of brand new tubular LCA's is 91 bucks. Check it out!
<blockquote>quote:</font><hr>I run hotchkis boxed trailing arms and pan hard rod.
<hr></blockquote>
I could quote several experienced autocrossers (including Sam Strano, and Louis G. even though he is a road racer) to support what I said.
I am talking about taking the car to its limits -- autocrossing. Its not something your going to be able to test on the street very well unless if you like risking your life. [img]smile.gif[/img]
If your car is a drag-racer/street car only. Then boxed will probably be ok. Just don't street race & take a corner really fast.
[ November 01, 2002: Message edited by: strobhen ]</p>2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
IMHO, the bushings are the most important thing with LCAs. Rubber has a lot of virtues here. Other choices are:
Rod ends. Best from a chassis point of view. The problem is you need good ones and they need to be maintained well. It's not easy to figure out how to get good ones and maintain them. If the rod ends screw up, catastrophic failure is possible. SCCA insists that rod ends have special (captive) mountings to protect against this.
Poly. Worst from a chassis point of view. When just one wheel moves up something has to twist and the bushings are the obvious place, especially if the LCAs are strong. These are good for straight line only and how many of us have a pure drag car, not street driven?
All in all, if you're going to change LCAs, the 1LEs (rubber bushings) are probably the best choice for most people.
[ November 01, 2002: Message edited by: V6Bob ]</p>2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
[ November 01, 2002: Message edited by: strobhen ]<hr></blockquote>
Oh ok, never knew this.
And I never took my car to the extreme before.
Sure powersliding on the street a couple of times but I never autocrossed it.
Thanks, I did not know thatRace car - gone but not forgotten - 1997 firebird V6
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 days ago
