ABS is gone - FirebirdV6.com/CamaroV6.com Message Board
ABS is gone
  • ABS is gone
    What most commonly goes on the f-body?
    The abs sensors? Unit? or Pump?
    Well now i remember when I took it to the shop the a while ago, they said it looks like the module is bad.
      My module went bad, but I have been to cheap to get it replaced so far.
        check your fuses, too
          Okay, ill check the fuses [img]smile.gif[/img]
            First check all the fuses, and then check to see if your 3rd brake light is out. GM put that light in the system, so if it blows, then the abs light will be thrown. Good luck. ;)
              I replaced the 3rd light, the abs is still on.
