My rearend feels loose - FirebirdV6.com/CamaroV6.com Message Board
  • My rearend feels loose
    ok, when i'm going around a turn even at slow speeds or going over bumps i feel my rearend is loose side to side. when i go over a bump it makes a noise going side to side. what could be the problem???
    1996 Chevy Camaro SS<br />#67 of 2,410 made that year with the slp package<br />Street Lethal Fbody Association Member<br /> <a href=\"http://www.cars-on-line.com/97cam11475.html\" target=\"_blank\">http://www.cars-on-line.com/97cam11475.html</a>
    ANY HELP PLEASE!!!!!!!!!!!!
      Be more descriptive about the noise. Solid axle will move on bumps.
        If it's really side to side, it may be the Panhard rod, most likely either the bolts or the bushings.
        [ April 04, 2002: Message edited by: V6Bob ]
        [ April 05, 2002: Message edited by: V6Bob ]</p>
        2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
          my car was doing this, check and tighten all rear suspension, panhard,lca, ect... also check for visible deterioration of the bushings.
          99 Dodge Quadcab<br />Traded: 2001 Camaro(will be missed)<p>Be wary of anything that can bleed for 5 days and live....
            Check the front suspension as well, specifically for a broken Front sway bar endlink. With only a rear bar (working), you'd be sliding like hell.
            -Rob
