19mm rear swaybar bushing - FirebirdV6.com/CamaroV6.com Message Board
  • 19mm rear swaybar bushing
    Does anyone see a difference between the bushings in the Energy Suspension 3-5161R kit vs. the 9-5106R universal bushing?
    This is crazy. You can buy the endlinks, and you can buy the "kit" (which includes endlinks and bushings) but you can't just buy the bushings! ES doesn't list an application specifically for the 82-02 Fbody 19mm rear bar.
    I already have endlinks and I want to get bushings now. The universal 19mm bushings/brackets are half the price of the "kit" which is why I don't want to buy new endlinks when I don't need them.
    how much woudl you sell me the rear endlinks for? I might be interested in buying them, if you want to split it up.
      You can get poly endlinks at Advance for like $6 each - they have the $5 rubber and the poly are the "Heavy Duty".
      When I took the saddles off the new rear to check the bushing size I noticed they are already poly. Heh, the previous owner put black ones on, I figured they were the stock rubber ones until I looked closer at them.
      But anyway, for anyone else who needs to replace bushings, the universal ones should work. They're the same design and size as the stock ones.
        yeah if you weren't going to sell me the endlinks I was gonna say they sell a bunch at advanced, not sure if they had 19mm seemed mos were listedl like 9/10ths inch, but looked close to like a 19mm one.
          Don't get either. Get these:
          http://www.energysuspension.com/pages/swaybbct.html
          Raven
            The rear I bought already has the poly bushings on it, but the stock brackets. I had poly endlinks and front bushings already. I never greased any of them, and I've never heard any of them squeak.
            Does everyone have problems with poly stuff squeaking?
              6 days ago
