Yeah I noticed that too, the 3rd Gen bars are huge compared to 4th Gen. Are you sure that's not solid though? Anyway, yeah they have the same connection points. You will just need the bushings to match. Endlinks should be the same.
What does a large rear bar help in drag? Does it help to keep the rear of the car from twisting?
its worth it for $20 to just try. but I am about 75$ sure it will work.
only thing that mighyt be different is I know the rear axle is wider on a 4th gen, but you can sort of universally mount the sway bar to the rear axle so it should be fine.
