I just converted my rear brakes from drum to '98 disk (off ls1). So far the only prob I've encountered is the e-brakes. What do I need to do to convert these so I don't die. :D
e-brake conversion...
Some sort of non-yours cables. Not sure if they're off a V8 or a different V6, but they need to be swapped. Check a search for "brakes after rear swap" or something. Good luck.
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
You need the rear cables from a disc rear end. They are different than a drum rear. It takes two cables, they run about 40 bucks a piece.97 Silver Bird<br />3.8 M5 Bone Stock Engine<br />15.528 @ 88.96 bone stock<br /><a href=\"http://www.fbodyenhancements.com/\" target=\"_blank\">www.fbodyenhancements.com/</a>
I had the same thing done. The cable pull positions aren't in the same place. The shop had to WELD a bracket on each side of the rearend. I'll try to get some pics before this weekend.
Later,
TreborSLP CAI, Flow Master exhaust, Pace Setter ceramic coated Headers, Hi-Flo CAT, Stage 1 clutch, Posi rear end, 180 thermo, Edelbrock C/O front H/D rear shocks... More to come.
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 days ago
