Put on a 1LE swaybar with poly links, now it squeeks. - FirebirdV6.com/CamaroV6.com Message Board
  • Put on a 1LE swaybar with poly links, now it squeeks.
    I got the bar for free helping a friend move, so I decided to put it on.
    Holy crap what a difference! I love it.
    My only concern is that since the bushings that hold the bar to the chasis were in good shape, and since they are 1le, they are very hard rubber, so I used them instead of poly bushings.
    Handles great, but for some reason it squeeks alot. Anyone else have this problem? I didn't remember seeing a grease fitting on the bushings either... Hmmmmm. Maybe I need to take the bushing back off and wipe some grease inside them. I dunno.
    1997 Dodge Viper GTS
    You're going to have to remove the swaybar again and grease inside of the bushings. It shouldn't make any noises after that.
      yea you have to lube it
        Some greases can soften or swell the rubber bushing, so be careful on what you use.
        I've got some teflon tape that we can wrap the bar with that will help too. It's not the thin white plumbers stuff, but a thicker tape with a good adhesive on one side. I'll have to get it to you this weekend somehow.
        2001 Pewter Firebird Y87, M5
        Go Sabres!
          Hmmm.... that sounds kinda cool Jeff. I will email you about it.
          Would it just be easier to put on greasable poly bushings?
            this sounds like a good upgrade whats the size of this piece ?
            1997 Camaro LS1 RS
            1994 Camaro - Sold
            1999 Trans am Vert - Sold
            A Few Mods....
              Stock was 30mm.
              1LE is 32mm.
              Doesn't seem like that big of a jump, but the car is WAY flatter in the turns now.
                Did you notice how the stock rubber bushings felt about as stiff as packing foam?
                  Sway bar stiffness is (diamter)^4 - small changes have big effects.
                  Ryan: I'll have to let you take my car out for a spin when we do your bar, so you can see how the Strano package feels..
                  Go Sabres!
                    Alright sounds good. I definately plan on buying the strano bars now, because if going from 30 to 32mm made a such a good difference, I really want to try the 35mm.
                    The stock rubber bushings did feel like packing foam. The stock 1le bushings, however were very hard.
                      Yeah I am eventually going from a 32/21 on mine to a 35/21
                      2002 5-spd NBM Camaro
                      Details: www.1lev6.com
