I recently installed a prothane tranny mount and hotchkis panhard bar and LCAs. After the LCAs and panhard bar there was a little bit more vibration in the back but only over rough surfaces. After replacing my shattered tranny mount with a poly one I have massive vibration at high speeds and low speeds is enough to make the passenger seat shake no matter what. Any ideas? I'm thinking I need new shocks
Alot of rear vibration at high speeds
00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own riskTags: None
I figured the vibration would be bad but high speeds make the chassis go nuts lol. Feels like the tires are still firm on the ground just the chassis is vibrating alot.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
Hmm thanks for that little insight there . Forgot when one of my tires blew out they put a "like" tire on the back. Its basically the same size as mine.. Its just bigger and different tread. Time for me to go talk to discount tire =).00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
