Corvette Wheel Sizes On Camaro - FirebirdV6.com/CamaroV6.com Message Board
  • Corvette Wheel Sizes On Camaro
    Search didnt bring anything up...
    I was wondering if I could fit the 18" corvette wheels front and rear without rubbing. What size tires would i have to use?
    http://cgi.ebay.com/ebaymotors/ws/eB...936586519&rd=1
    Those are the wheels I am looking at. I saw them on a camaro the other day and they looked sweet.
    I would like to get 18's if possible. Do these wheels weigh more than the Z28 16in. wheels I have on there now? How much will this slow me down if any?
    2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
    275/35/18s will fit.
    2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
      Yes they will fit. I have the Z06 18x9.5 rims and have no rubbing front or rear. They will be just a little heavier because of the added size. They will also slow you down a little too. I will say you will notice a difference when you put them on but if you decide to boost your HP that will make up for that.
        yes they fit.
        2002 5-spd NBM Camaro
        Details: www.1lev6.com
          Will I need adapters or will they bolt up?
            http://www.slponline.com/inst/80090.pdf
            I have seen these wheels used on Fbodies before and I don't recall anyone saying about them rubbing in the rear. That was using the C5 front however, which is a 17x8.5 with less backspacing.
            I think you're going to have problems with rubbing putting a rear wheel on the front because of the increased backspacing.
              I think those style corvette wheels on your ebay link are 17" fronts though. You might want to check with seller. Thats how they cam e on the corvettes. 17" front and 18" rear. But if you got them 275/35R18 should be the tire you need.
                ^^ Yeah, the seller says 18x9.5 x four but a stock Corvette would have 17x8.5 fronts.
                You guys that put 18x9.5 "Z06" wheels on your cars are replica wheels that have a corrected offset. Factory C5 rear wheels have a 60-something offset, could cause problems if you put them up front.
                  Ya, I was just showing the style I wanted. So the replicas shouldnt need any kind of adapters.
                    I would check with the seller to see if they measure x120.65mm or x120.5mm. if they are 120.5 they will fit on, but there will be problems and i was told they rattle and can possibly fall off. Make sure they are 120.65mm
