I'm going to be running a turbo 3.8 with tons of torque and an automatic. I want to leave off the foot brake and drums have superior holding power compared to disks when holding boost at the line. Any of you v6 guys use a weld pro star on the rear? Specifically a 15x10 with a 7.5 inch backspace......Any fittment problems? I know the PBR rear calipers need grinding, but what is the clearance with drums?
Brake clearance with pro stars
i run 15x8s with 5.5 backspacing and i had to grind the brakes and use a spacer to make it fit.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
Originally posted by Little G:
i run 15x8s with 5.5 backspacing and i had to grind the brakes and use a spacer to make it fit.<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
With rear drums I would think they would fit fine with a spacer of some sort. I would check over at LS1tech since a lot more people over there run slicks and I'm sure someone with drums has them.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
