Hello, does anyone know if 1993-02 SS Springs sits lower then 1993-02 V6 Springs? I want to put my stock springs on my 2001 V6. But I remember it looking really really high. But when looking at stock ss camaro's, it looks like the car sits lower then ours. So is there a difference in ride height with the ss springs and v6 springs?
Do stock SS springs sit lower then stock V6 springs?
I THINK SS springs are the same as Z28. I will be putting Brand new Z28 front springs and struts on my 1997 v6 this weekend. I will also be putting air shocks on the rear. Im hope all this will raise my car between 1 and 2 inches.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Someone just replied back to one of my post on norcal-ls1.com. And that person said that ss camaro's do sit a little lower then v6/z28 camaros. They came out with stage1 and stage2. I guess the only way to find out is to buy some ss springs.<a href=\"http://www.dontforgettotakeyourvitamins.com\" target=\"_blank\">www.dontforgettotakeyourvitamins .com</a>
Wouldnt the car actually sit higher in the front, assuming the LS1 weighs more then the 3.8?
2000 Pewter Pontiac Transam 360rwhp, 370ftlbs
1998 Sport Gold Metallic Chevrolet Camaro *SOLD*
1974 Silver Chevrolet BIG BLOCK Corvette
My assumption would be that the car is going to sit higher. The SS springs are designed for the weight of the V8 (although the LS1 doesn't weigh much more, it still makes a difference).Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
Level 1 and Level 2 SLP springs are lowering springs made by Eibach. Even though a V8 has a little more weight than a V6 the front is still going to drop with SLP springs, just not as much.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
why would you want to lower your car... mine is all stock and i drag my nose and bottom out all the time. I raising mine this weekend as i said above.. ill post pics when im done.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Putting z28 springs on the front with new struts. Im hoping for an inch or inch and a half. Putting Air shocks on the rear to level every thing out. Rear stock springs are pretty weak.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
it depends on the year and the options, my one roomates 99 ss has the higher performance suspension (Much stiffer springs and revalved shocks) that was offered and it actually sits a 1/4" higher than my car. My other roomates 02 35th ss sits about the same as mine and his has the same suspension as the Z28.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
why would you want to lower your car... mine is all stock and i drag my nose and bottom out all the time. I raising mine this weekend as i said above.. ill post pics when im done.2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
Z28 springs will raise a v6 car 1.5 inchs.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
I think you are talking about lt1 z28 springs because if i remember right our engine weighs almost as much a an ls1 but i could be wrong here.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 days ago
