i dunno if i need a chassis lube job or what but whenever i got over speed bumps slowly and whatnot my rear end squeks like a mofo?? any ideas. its annoying and the doesnt look good for the ladies.
Squeeky suspension
Mine started doing that when my shocsks were going....replaced the shocks and it is still doing it on the ds, damn annoying......I hear the sway bar bushings are prone to go bad.....I will let you know when I replace mine if the squeek is goneJoel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
<blockquote>quote:</font><hr>Originally posted by CARdiac:
Mine started doing that when my shocsks were going....replaced the shocks and it is still doing it on the ds, damn annoying......I hear the sway bar bushings are prone to go bad.....I will let you know when I replace mine if the squeek is gone<hr></blockquote>
My front sway bar bushings aren't lubed enough and it sqeaks when I go over bumps at slow speeds.<a href=\"http://www.onid.orst.edu/~waltejam/\" target=\"_blank\">98 Bright Red Camaro</a><br />Too many mods to list....check my website
First thing I would do is lube the swaybar bushings and endlinks... After that check any other bushings that move over bumps. My swaybar in the rear was causing me this exact same problem a year ago, lube solved it.2002 5-spd NBM Camaro
Details: www.1lev6.com
My rear squeaks even when I accelerate, when the rear is setting back from a dead stop, I get the squeak tooJoel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
energy suspension recomends blue marine grease, since it is waterproof.Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
