I know some of you with 3.4s have done this and I have been thinking about doing it. If I could find a z28 rearend from a junkyard for cheap how hard would it be to fit it to my car. I think I would need to fittings on the brake lines to go to the disk brakes, but not sure. Also would I need to go ahead and get the z28 driveshaft to make it easier. Or is it just easier to get a conversion kit. Any info would be appreciated.
3.4 rear disk brake conversion
I personally think a brake conversion kit is better. their is very little difference between the various camaro/firebird rearends. Mainly just the different type of brake setups. If you want a stronger rearend then go buy a moser 12 bolt or currie 9 bolt rearend. If you just want better brakes then get the drum to disk conversion or upgrade the front disks to bigger rotors/better calipers. Some of the companies inlcude Baer or wilwood. Their are others but they are more expensive. I suggest just doing the conversion if all you want is better brakes/stopping power.1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
I ordered a rear disc brake conversion kit from speedautomotive.com. After ordering and paying I was told it would be shipped that day and arrive no later than friday. Of course it was not here on friday so I gave them a couple of extra days to be sure they had time to send it. I still had not recieved it by the following thursday so I gave them a call. They had not even removed the brakes from the parts car yet! But I was told that they were going to send it that day and should have it no later than the following friday. Told them nevermind just cancel. So I would not recommed picking up one of their rear brake kits.RED 1995 CAMARO 3.4L<br />Moroso cai, ASP Underdrive Pulleys, B&M Shifter, Flowmaster 80-Series Muffler, Polygraphite Sway Bar Bushings, Endlinks, and Panhard Rod Bushings
