After a tireless (no pun intended) search on the forum, I have a question that I hope I'm not duplicating. I would like to save my stock wheels for the oh so joyous New England winter, and step up to some low profile 17"s for the summer. What size tire/wheels would I have to get without affecting my speedo? I tried to understand the #'s game, but I can't figger it out. [img]graemlins/dunce.gif[/img]
Wheel & Tire Question
for 17" you can run the following widths/ratios
255/45R17
275/40R17
285/40R17
All will work without affecing the speedometer.2002 5-spd NBM Camaro
Details: www.1lev6.com
Cardinal, the 255/45/17 and the 275/40/17 have a .4" difference in height, and a difference of somewhere between 12 and 36 rpm, depending on where you get the figures (BFG's site shows 12 rpm difference). Dewey, depends on which size tires you have now. To find out for sure, check your tire size now, then go to the manufacturer's site (probably going to be Goodyear, if you have the stockers), and look up their tires. They have a tire spec sheet, that will show, among other things, the tire height.
There will be a bit of variation from what their specs are, because they don't always measure them on 16x8 or 17x9 wheels, but it's close enough.
Anyways, after you get that, start looking at other sizes youd like, and compare the heights with yours.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
