Got a friend thats sellin his 1LE upper a arms. He has poly bushings for them, but never installed. Question is did the 1LE a arms weigh any less than our stock v6 arms do? his car is a 94 1le and my car is a 94 too. Also, is has anyone replaced all the front a arm bushings with poly? I have heard its a noticable gain.
1LE A Arms...and poly bushing?
You talking about Anthony? They are probably the same as stock except harder poly rubber. But on a 94 that rubber will have deteriorated some by now. And the ball joints will probably need to be replaced by now also.
As far as poly I was advised against it by many people.
The ONLY difference between 99% of the 1LE and stock parts is the bushings. The only exceptions are the sway bars, because they're bigger.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
