i fishtailed and did a 180 into a curb, ruined my tire and my rim, and so i put the spare on and drove home, now i notice when i brake i get this pulsating feel from the brakes.. does anyone know what this could be.? i really need to know because my car could be worse than i think
new pulsating feel when i hit the brakes..
Ok the rotor is usually a nice flat surface... Warped means now there are small hills or valleys instead of a nice flat surface. Warping be caused by a lot of things but a common cause is hard breaking (causing the rotors to heat up) then fast cooling (going through a puddle?). The quick expansion then shrinking causes warping.98 Silver Camaro V6<br />15.238 @91.74 w/ 2.288 60\'<br />Mods: K&N, FTRA, Pacesetter Headers, Spec 3 Clutch, 160 Thermo, TSP Rumbler, 3\" Catco, Whisper Lid, 3.42\'s w/LSD, Aluminum DS, Man Fan Switch<br /><br /> <a href=\"http://www.cardomain
If you didn't feel it before the accident I doubt it's just a warped rotor. When the wheel hit did it contact the caliper? Possibly bent the caliper or mounting bracket enough to cause it to grip the rotor unevenly.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Originally posted by 00firebird:
I have a picture that i took of my rotor because it looked so rusted..1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
if its one warped rotor, AND in the rear, doubt you'll feel it. rear brakes have less then half the stopping power and divide that by two, and you're talking about a fairly small amount.
So if its from only one rotor, its worse than just being warped.
my guess is that your front ones are warped but you just never noticed it until after the accident.
I have a 2001 and I've already replaced the rotors, and I can tell I'll have to over the summer again.
Replacing rotors is as easy as taking the wheel off. so just buy the rotors you need and take care of it yourself, if that is all thats needed.
00firebird when is the last time you changed your brake pads i used to think my rotors where warped then i changed the break pads and it went away, might want to look into that if you cant afford or are to lazy to replace a rotor jsut a thoughtno fate but what we make<br /><a href=\"http://www.cardomain.com/memberpage/748167/1\" target=\"_blank\">http://www.cardomain.com/memberpage/748167/1</a>
lol yea FunkZ michigan roads suck, but with the salt, were lucky if we can even get them out here to salt the roads down, and it doesnt help when it snows on sunday or x-mas, cuz then they wont come out at all, and if they did that might have prevented an accident i got into on x-mas 3 yrs ago99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
alright, I got my tire and wheel put on, drove around for about 5 minutes... i noticed i still felt the pulsating feeling... it was worst when i got up to about 40-50 and then slowly applied the brake.
I did not notice any visible damage to the rotor, could there be something else causing this? could it be the tcs ?
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 days ago
