coilover system.... i need help guys - FirebirdV6.com/CamaroV6.com Message Board
  • coilover system.... i need help guys
    alright, i spent somthin from 500-1000 dollars to have my eibach prokit, bilstein shocks, bmr sway bars, adj panhard bar, headers, msd wires and new ngk iridium plugs alll installed at once. now im anoyed with how my car sits, so im ready to go the distance, coil over kit, but i need to know, how much for install (estimated? and how hard is it to adj, how much can u lower and how hard is the ride? how much better is handeling?
    [ January 30, 2006, 06:10 PM: Message edited by: Chris Camaro ]
    2000 3.8 Camaro M5<br /><br /> <a href=\"http://www.cardomain.com/ride/832316\" target=\"_blank\">http://www.cardomain.com/ride/832316</a>
    Install shouldn't be more than any other spring/shock install, plus maybe 1/2 hour to adjust the ride height. Add alignment of course.
    How low? On my Ground controls, probably until the tires scrape in the wheel wells if I wanted. How hard? The lower you go, the stiffer springs and shocks you need to keep from constantly bottoming out.
    2001 Pewter Firebird Y87, M5
    Go Sabres!
      where shouldi buy?
        Talk to Sam Strano at stranoparts.com
        He'll help you with the right spring rates (you get to pick them) and will give good advice on shocks too..
        Go Sabres!
