ok, grab the 2 oclock position on your steering wheel and pull down and toward the left. does your steering wheel rock back and forth this way. mine does and i have seen a few other chevys that do the same.
does your steering wheel do this??
96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>Tags: None
actually...yeah...mine does once in a while...i'v echecked the psi ..i get them computer alligned and ballanced...i dunno...it doesnt do it TOO much.. so i guess i never bothered to get much into it<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
i mean, just the steering wheel. like when the car is parked and not moving. just grab the top right of the wheel and see if it pulls down and toward the left. i do have some alignment issues though, well a thumping in my front end. it still drives straight as an arrow though....a cam-arrow,
sorry, lame joke i know I couldnt resist96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
Raven
there are several areas that can cause this. Play in the rag joint, play in the inner or outer tie rod ends, or play in the rack itself. Most often the rag joint becomes loose and can be solved by the rag joint eliminator by unbalanced engineering. Have an assistant turn the wheel while you check for slop in those three places.
NOTHING TO DO WITH STEERING THE CAR> just the steering wheel it self bobs from top right to bottom left.
No slop in wheels, jsut the steering wheel96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
Ah... the tilt column is assembled in sections and there are a couple of bolts that frequently loosen over time. This allows the column to get play in it. It is a royal PITA to get to. The steering wheel/airbag are removed and the column is disassembled from the top, piece by piece until you finally get to the few bolts that require re-tightening. Then you reassemble. It is much easier by removing the entire column from the car and doing this on a bench. Plan on at least 3-4 hours, not including re-installing the column in the car.
urggg, i think i will wait till the steering wheel falls off before i do that, I ROYALLY HATE dealing with steering columns. FOr some reason there is always parts left after im done, if i do it ill have my friend help, he has done steering before. thanks96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
James "12secondv6" would call that weight reduction.I solemnly swear I am up to no good.
I know what your talking about. Mine does it also. I blieve its in the verticle adjustment on the stearing colum. It gets annoying sometimes when I'm driving aggesively on the highway but other than that it really doesn't bother me.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...6 days ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.4 weeks ago
