hey guys when I put my LCAs on I obviously didn't grease the bushings up enough. SLP sent me 2 packets of grease for the LCAs and panhard rod but in the install process I lost one so I had to ration it out. [img]smile.gif[/img] anyways, the control arms are squeeking way too much at slow speeds. i haven't gotten up under the car again, but is there a trick to greasing them up again without completly taking the arms off again?
greasing the bushings
they sent me the non-melting grease with the poly bushings. doesn't slp's version of the LCAs just use the different bushing? i hope it is not supposed to sound like this....my car sounds old and rickety going over bumps!!
:D Well thats sort of what I'm wondering... My polys aren't greased up correctly, just didn't know if there is a trick to re-grease them without completely taking the control arms off. Once that bolt comes out the axle will shift and with my puny stock jack I won't be able to be agressive with it trying to line up the holes.
Oh cmon. I took my control arms off so many times. Both at once also. All you need to do it push the axle in whatever direction you want. If I can do it with one hand while putting the bolt with the other it can't be that hard. Plus it never shifted on me when I only had one control arm out. I took my axle completely off and never spend more then 10 seconds on pushing it in the correct spot.
I always jack it up and also put jack stands under it and put jack stands under the body if I'm going to remove shocks. With the axle on jack stands and no weight on it since the body is also on jack stands it moves around quite easily.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...5 days ago
