hey i got my taxes done and i am going to have $850 by 2 weeks. i wanted to do springs and shocks and rotors and hotchkis rear suspension. is it possible. if not what do you recommend. 850-1000 dollars is the range. any opinnions are welcomed. [img]graemlins/burnout.gif[/img] [img]graemlins/banana.gif[/img] [img]graemlins/naughty.gif[/img]
suspension upgrades
springs n shocks are about $600
+ rotors (i recommend www.rotorpros.com ) $200
LCA relocation brackets $50
= $850 +install prices unless u do it urselfK&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
Are you tring to handle? Drag? Or street car?1999 Pontiac Trans Am M6 Far from stock.....
Well if your going to set up to handle.
The most important thing on our cars is 1st: Shocks 2nd: Swaybars 3rd: springs.
Just going shocks+ front bar will make a world of differerce.
Im doing a re-valved bilisten set with strano 35/22 hollow bars.
The qestion is can your front springs handle the big bars? A good spring set to use would be a prokit.
I would give strano a call though and expalin your situation and he will help ya out [img]smile.gif[/img]1999 Pontiac Trans Am M6 Far from stock.....
talked to strano today and he helped out alot, save up about couple mor ehundred dollars and get either :
a.revalved bilsteins with lowering springs 740ish
b. adj. konis(just as goood as above) 700(lifetime warr.)
c. panhard bar: 140
sway bars: set is 350ish
but with you for now i would go A or B and add C to those which would be about 900 ish!
