I have like a bad vibration throughout the car when I get up to around 60-75 mph. It started a little while after I got new tires in the rear. I have Bridgestone PotenzaRE910's in the rear and whatever tires came with the car up front. The front tires looked new when I got the car that's why I didn't get new ones up front. Anyways, after i'd say a few hundred miles after the new rear tires, I've noticed this vibration. I can put my hand on the steering wheel and just watch it shake like crazy. I only feel the vibration effect between these speeds. Could it be because I have two different makes of tires? Or maybe I just need to get the front tires balanced??? I did a front end alignment when i got the rear tires, but didn't balance them. Anyone???????????
Bad Vibration around 60-75 mph??????
<blockquote>quote:</font><hr>Originally posted by 97camRS:
I have like a bad vibration throughout the car when I get up to around 60-75 mph. ... I can put my hand on the steering wheel and just watch it shake like crazy. I only feel the vibration effect between these speeds. <hr></blockquote>
What you are describing is the classic symptom for wheel balance being off. It will start up around 55-60, and drop off after a point. (if you go far enough up, it will start again...)
If the steering wheel moves back and forth by itself, it's the fronts (not to say the backs are balanced, but you know definitely the fronts need work).
If it didn't start at exactly the same time you got the tires, then you probably threw a weight off one of the wheels going down the road.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
So I guess I should get the front wheels balanced and see if it still does it? I also notice everyonce in awhile when I hit the brakes the car will jerk to the right, what could that be? It's like a bad jerk too, like someone just grabbed the wheel and yanked it to the right!<a href=\"http://www.cardomain.com/ride/2093533\" target=\"_blank\">CarDomain Page</a>
Got all four tires balanced this morning and No vibration so far. Had it up to 70 on the way back to work and there was NO vibration at all. Sweet!!!<a href=\"http://www.cardomain.com/ride/2093533\" target=\"_blank\">CarDomain Page</a>
