Yet another odd vibration question - FirebirdV6.com/CamaroV6.com Message Board
  • Yet another odd vibration question
    Hey. I just started noticing a vibration when Im going like 70. It only happens when I make right turns. The harder the turn, the heavier the vibration. It doesnt happen at all below 60. It also doesnt happen when I go straight or turn left. Any ideas as to what it is?
    I dont know if this has anything to do with it, but a couple of weeks ago I had a hole in my right rear tire repaired. I dont remember the vibration before that, but then again, I dont hear very well and my memory sucks.
    Thanks for any help.
    All gone :(<br />Best ET ever: 14.3 (I think)<br />----------------------------<br />Check out my site for exhaust clips, burnouts, and pictures, and the supercharger throttle body mod.<br /><a href=\"http://www.geocities.com/net_addict/index.html\" target=\"_blank\">Click on the Firebird</a>
    i'd check the tire pressure and maybe it needs to be balanced
    <b>*§*Julian*§*</b><br />*~*~*~<br />2000 Grand Prix GTP -Daytona 500 Edition (only 2000 made) - Supercharged 3.8L V6<br /><br />1998 3.8L V6 A4 Firebird w/ W68 package, Y87, T-TOPS!<br /><br /><a href=\"http://myweb.usf.edu/~jadidona/index.html\" target=\"_blank\">MY SITE - CHECK IT!</a>
      Like SuprSpdDB7 said check the tire pressure when cold and also if thats ok then have the tires balanced and rotated. Does your car drift at all if so you may need to get an alignment. But most likely its just needs to be balanced and rotated and possible some more air pressure is needed in that particular tire. Always check the tire first before doing anything else.
      1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
        If you drove it long while it was low/flat, or if the repair guys overinflated it, you may have a bad belt.
