End link length - FirebirdV6.com/CamaroV6.com Message Board
End link length
  • End link length
    I just put a 1LE swaybar on the front, and had a question on the length of the spacer for the end links. I didn't order endlinks as I had originally planned on just upgrading the rubber bushings to poly. Well, bending one of the endlinks put that idea to rest.
    After some searching, our stockers are 2 5/8". I checked around and couldn't find a definative answer, but for a 32mm swaybar 2 7/8" seems recommended. For my 1LE can I use a 2 7/8", or should I stick with the 2 5/8" (no they do not make a 2 3/4" - already looked).
    Oh, and I did search.
    <a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> <br /><b><a href=\"http://www.cardomain.com/id/c_o_jones\" target=\"_blank\">Cardomain</a></b><br />--This doesn\'t change the fact that I am ~The Guru~ who still kicks puppies...
    http://www.lmperformance.com/1568/7.html ..2-7/8 [img]smile.gif[/img]
      If you car is lowered, it will make a difference too. You are SUPPOSED to get endlinks that will make your sway bars level when the car is on flat ground with no load on it. I don't know exactly what that length is right off hand, but that is technically the best way to set it up. I don't know how much difference it would really make though.
        I bought 2 sets of poly endlinks at Advance Auto. (2 different stores on 2 different trips) The front and rear are supposed to use the same part. I got the TRW 18203HD both times. One set appeared to be stock length and had red bushings, the other set was shorter and had blue bushings. I put the shorter set on the rear.
          :rolleyes: You know, I read that whole page before, but somehow managed to skip right over the 32mm(1LE) portion.
          "Here's my sign" [img]graemlins/slap.gif[/img]
            Here's a question:
            My car is lowered about 1.5" and I'm running 32/21 mm sway bars. What is the reccomended length on the spacers for that?
            ~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
