I have a 94 3.4L camaro with the stock rear end. All my springs and shocks are worn out and need to be replaced. But I also have plans to replace the stock rear end with a rear end off a 96 or 97 rear end with LSD and disk breaks. But my question is are the springs and shocks going be compatible with the two rear ends?
spring and shock question
Yes, both V6 and V8 can use the same springs and shocks.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Spring rates are different those, Just remember it may handle worse or better depending on what you go with. They also will lift the car slightly.2005 Cavalier LS Sport M5<br /> <a href=\"http://members.cardomain.com/firefighter8615\" target=\"_blank\">http://members.cardomain.com/firefighter8615</a>
