I'm considering buying a strut tower brace with money I got for Christmas from my grandparents. The thing is I've read some posts that say the STB didn't help and some that say they did. I want to do a poll to find out what the verdict is. I've put in an option to say if you don't have a stb (incase you're like me and want to be able to see the results).
Feel free to comment.
Thanks, Rob
29
Yes
13.79%
4
No
82.76%
24
I do not have one at this time
3.45%
1
I installed it at the same time as other suspension mods, so I do not know how much it helped me
0.00%
0
<b>2002 Pewter v6 Camaro</b><br />T-tops, Auto, stock GFX<br />mods: SSRA, Whisper lid, K&N filter, Borla cat-back, Pioneer HU, RF 6.5\" speakers, billet grill, clear corners, red tubing under hood, black CAMARO fill-in\'s, QTEC, GM power antenna, fan switch
yup..mines really just for looks..sway bars, 245mm tires, and LCAs were the kick @ss combo for me..im not exactly sure how much the pan hard bar does either
I noticed a little bit of difference when I put it on(only suspension mod at the time). It turned the corners a little bit tighter(front end anyways), but nothing groundbreaking. Also, I have a vert, so it was probably more noticeable than if you had t-tops or a hard top. :cool:
If you can get it cheap, it may be worth it...mine was a used one at $80(shipping included) and was already painted white to match my engine bay...so I thought it was worthwhile.
Yes, I know \"Artic\" should be spelled \"Arctic\". Can any of the mods change this?
Originally posted by ArticRider: I noticed a little bit of difference when I put it on(only suspension mod at the time). It turned the corners a little bit tighter(front end anyways), but nothing groundbreaking. Also, I have a vert, so it was probably more noticeable than if you had t-tops or a hard top. :cool:
yeah on a vert, it may acctualy make a non placeebo difference..
when i got mine it was one of my first mods to the camaro.. it was disapointing..
i ended up taking it off and leaving it off after my superchager install because i got sick of it getting in the way..
I thought it made a difference on mine. My car felt really solid when I corner, it doesn't flex as much.
<i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
Thanks for the comments. After reading this, I've decided that (since I don't have a 'vert), I can't justify spending the money on one. Looks like I'll just put that money towards gears and a LSD.
Its mainly for looks, very little help with front end stability.
Originally posted by Rob@USC: Thanks for the comments. After reading this, I've decided that (since I don't have a 'vert), I can't justify spending the money on one. Looks like I'll just put that money towards gears and a LSD.
That seems like a better way to spend the money. You'll definitely notice more of push when you hit the gas once you get those installed. :cool:
haha..i think it may help but just on a level that you dont really notice (therefor whats the point) ..if you really want some cornering power get a set of sway bars and fat tires..i have the Spohn sway bar set from fasttoys.net and 245 wide tires and my cornering RULES..you could also look into sub frame connectors (i also have a STB, LCAs, and a pan hard rod)..could adjust the camber too but i dont like to play with that [img]smile.gif[/img]
You call 245's wide? better then stock yes wide no. I was running 285/40/17's, Those were wide!
I think you should allocate the moola to Sub-Frame Connectors, especially since you got T-tops. It will help keep the rattles at bay and it has a bigger difference than an STB.
I got the SFCs first, then I got the STB. Both made a differece. The SFCs I noticed right away when I entered the on-ramp loop to the freeway. It got rid of the tire rub on the frt lt wheel well whenever I go 35-40mph on the circular on-ramp.
The STB you can feel the diff when you are yanking left and right, it also got rid of this annoying squeak from the HVAC area.
1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
