i am gong to get the 1LE front/rear, but is it a good a idea to get Polyurethane bushings or should i just use the ones that come with them?
question with sway bars
1999 Pontiac Trans Am M6 Far from stock.....
Pics http://rides.webshots.com/album/5599...Dk?vhost=ridesTags: None
I recommend poly endlinks, and grease both the poly endlinks and the rubber D bushings which come with them. My rubber squeeked after a while but a little grease solved it [img]smile.gif[/img]2002 5-spd NBM Camaro
Details: www.1lev6.com
iam thinking of doing a whole 1LE package.
trailing arms, panhard rod, sway bars, and get a slp stb. Would this be a good start. Can i wait on the shocks and springs?1999 Pontiac Trans Am M6 Far from stock.....
is doing the endlinks that big of a deal?1999 Pontiac Trans Am M6 Far from stock.....
It seems if i get the 1LE sway bars from gmdircet it will be cheaper then slp, but i just need 1 or two of these 10221779?1999 Pontiac Trans Am M6 Far from stock.....
wow the site gave me a error and it still posted. o well1999 Pontiac Trans Am M6 Far from stock.....
Get the package lmperformance sells if you want both bars, endlinks, etc.
LCAs, PHR, both are good mods. If 1LE is enough for you, they're excellent deals.2002 5-spd NBM Camaro
Read the threads "rear sway bar??" and "more on the 1LE rear bar change..." below for some info and opinions on these "1LE" bars.2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 days ago
