question with sway bars - FirebirdV6.com/CamaroV6.com Message Board
  • question with sway bars
    i am gong to get the 1LE front/rear, but is it a good a idea to get Polyurethane bushings or should i just use the ones that come with them?
    1999 Pontiac Trans Am M6 Far from stock.....
    I recommend poly endlinks, and grease both the poly endlinks and the rubber D bushings which come with them. My rubber squeeked after a while but a little grease solved it [img]smile.gif[/img]
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      iam thinking of doing a whole 1LE package.
      trailing arms, panhard rod, sway bars, and get a slp stb. Would this be a good start. Can i wait on the shocks and springs?
        is doing the endlinks that big of a deal?
          It seems if i get the 1LE sway bars from gmdircet it will be cheaper then slp, but i just need 1 or two of these 10221779?
            wow the site gave me a error and it still posted. o well
              Get the package lmperformance sells if you want both bars, endlinks, etc.
              LCAs, PHR, both are good mods. If 1LE is enough for you, they're excellent deals.
                Read the threads "rear sway bar??" and "more on the 1LE rear bar change..." below for some info and opinions on these "1LE" bars.
                2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
