I'm planning on flushing my brake system with a power bleeder. I figured I'd just buy the best stuff I can find, some synthetic DOT 5.1 or something. Anyone have any suggestions?
What kinda brake fluid?
Motul or Castrol makes some of the highest temp fluid possible. I would probably just run a good DOT4.2002 5-spd NBM Camaro
Details: www.1lev6.com
I chucked the dot 5.1 brake fluid idea after reading some information and determining it would not be very compatible with our ABS system. You can put it in and run it, but there are no gains to be had from using it. It's also silicon based which gm does not recommend for its brake systems.
I picked up some ATE Superblue fluid.
I agree that sticking with GM's recommendation makes sense here.
But, FYI, it's DOT 5 that's silicone based, and DOT 5.1 is not. I don't know why they decided to use those confusing numbers.
[ December 30, 2003: Message edited by: V6Bob ]</p>2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
